Changes to Step #22
Edit by Julia
Edit approved by Julia
Deleted
Added
Unchanged
Step Lines
[* black] iPod Touch 5th Generation Repairability: '''3 out of 10''' (10 is easiest to repair)
[* green] While very difficult, opening the case and replacing components is not impossible.
[* green] The battery is flanked by notches that make prying it out of the rear case fairly easy.
[* red] Many components are soldered together, requiring either a very difficult or very expensive repair if any one part breaks.
[* red] NoThe Touch has no external screws, rather bothscrews. Instead, a combo of clips and adhesive make it difficult to open the case.
[* red] Cables connected to the logic board run over the top and connect on the bottom, making it difficult to remove the board or disconnect the cables.
