Help
iMac Intel 20" EMC 2133 and 2210 Inverter Replacement
Use this guide to replace your inverter.
Step 1 Inverter  ¶
Remove the two 13 mm T10 Torx screws securing the inverter to the rear case.
Step 1 Inverter  ¶
  • Remove the two 13 mm T10 Torx screws securing the inverter to the rear case.
Step 2  ¶
Pull the inverter away from the chassis and lift it slightly out of the rear case.
Step 2  ¶
  • Pull the inverter away from the chassis and lift it slightly out of the rear case.
Step 3  ¶
Disconnect the inverter cable by simultaneously squeezing the locking mechanism and pulling the connector away from its socket.
Step 3  ¶
  • Disconnect the inverter cable by simultaneously squeezing the locking mechanism and pulling the connector away from its socket.
Step 4  ¶
Lift the metal case off the inverter.
Step 4  ¶
  • Lift the metal case off the inverter.
