Help
Lenovo Yoga Tab 3 8 Camera Replacement
Removal of the Camera for replacement in the Lenovo Yoga Tab 3 8.
  • Author: Nicklaus Krems
  • Time estimate: 15 - 20 minutes
  • Difficulty: Difficult
If you are following this guide, that means your camera is not responding on your Lenovo Yoga Tab 3 8. Before starting to work on your device, it is advised to back up any important files just in case something happens. You will want to make sure you have the device powered off to prevent harming yourself or damaging your hardware, especially because you will have to remove the battery to remove the camera. To make reassembly easier, be sure to avoid misplacing the small screws by keeping track of them as you go.
Sections
Tools
Step 1 Camera  ¶
Locate the silver camera mounting bracket between the power button and the camera housing. Remove the two 3mm screws on the camera mounting bracket using a PH00 screwdriver.
Step 1 Camera  ¶
  • Locate the silver camera mounting bracket between the power button and the camera housing. Remove the two 3mm screws on the camera mounting bracket using a PH00 screwdriver.
Step 2  ¶
The camera housing is held in place by a pin in the center of the grey hinge mount. Push and hold in the pin with the pointy end of a spudger while you lift the camera assembly out. The camera housing is held in place by a pin in the center of the grey hinge mount. Push and hold in the pin with the pointy end of a spudger while you lift the camera assembly out.
Step 2  ¶
  • The camera housing is held in place by a pin in the center of the grey hinge mount. Push and hold in the pin with the pointy end of a spudger while you lift the camera assembly out.
Step 3  ¶
Remove the three 5mm screws holding together the camera housing using a PH00 screwdriver.
Step 3  ¶
  • Remove the three 5mm screws holding together the camera housing using a PH00 screwdriver.
Step 4  ¶
Separate the camera from the housing by pulling it apart with your fingers. Separate the camera from the housing by pulling it apart with your fingers.
Step 4  ¶
  • Separate the camera from the housing by pulling it apart with your fingers.
