Help
Samsung NP350V5C-T02US RAM Replacement
This guide will help users locate where RAM is and replace it.
  • Author: Wanjun Xu
  • Time estimate: 5 minutes
  • Difficulty: Easy
This guide helps users to replace the RAM successfully by following these easy steps.
Step 1 RAM  ¶
Locate the RAM in the lower right hand corner.
Step 1 RAM  ¶
  • Locate the RAM in the lower right hand corner.
Step 2  ¶
Depress both sides of the lock mechanism at the same time using tweezers to remove the RAM.
Step 2  ¶
  • Depress both sides of the lock mechanism at the same time using tweezers to remove the RAM.
  • Since there are two RAMs, remove the other one by using the same method.
Step 3  ¶
After removing all RAMs, the empty space looks like this. Then users can install the new RAMs.
Step 3  ¶
  • After removing all RAMs, the empty space looks like this. Then users can install the new RAMs.
