Help
Trio AXS 3G Battery Replacement
If your tablet's battery no longer holds a charge, this guided will show you how to replace it with a new one.
  • Author: Michaela Causey
  • Time estimate: 15 - 30 minutes
  • Difficulty: Moderate
Sections
Tools
Step 1 Battery  ¶
The battery is the large, silver square inside the tablet. It is connected to the motherboard by two wires.
Step 1 Battery  ¶
  • The battery is the large, silver square inside the tablet. It is connected to the motherboard by two wires.
Step 2  ¶
Use the soldering iron to remove the two metal ends that connect the battery to the motherboard.
Step 2  ¶
  • Use the soldering iron to remove the two metal ends that connect the battery to the motherboard.
Step 3  ¶
Use the plastic card to pry the battery away from the device.
Step 3  ¶
  • Use the plastic card to pry the battery away from the device.
  • The battery is attached to the tablet by glue.
Step 4  ¶
Peel off the battery from the device to completely remove it.
Step 4  ¶
  • Peel off the battery from the device to completely remove it.
