Help
Acer Aspire 4810TZ-4120 Screen Replacement
To replace a faulty or a cracked screen, follow these directions.
  • Author: Sean Howard
  • Time estimate: 35 minutes
  • Difficulty: Moderate
Sections
Tools
Step 1 Screen  ¶
Locate and remove the  four (4) pads using Angled Tweezers Locate and remove the  four (4) pads using Angled Tweezers
Step 1 Screen  ¶
  • Locate and remove the four (4) pads using Angled Tweezers
Step 2  ¶
Remove the four screws that were under the pads Remove the four screws that were under the pads
Step 2  ¶
  • Remove the four screws that were under the pads
Step 3  ¶
Carefully pull the bevel (frame) off of the screen Carefully pull the bevel (frame) off of the screen Carefully pull the bevel (frame) off of the screen
Step 3  ¶
  • Carefully pull the bevel (frame) off of the screen
Step 4  ¶
Locate the four screws that are holding the screen in place Remove the screws Remove the screws
Step 4  ¶
  • Locate the four screws that are holding the screen in place
  • Remove the screws
Step 5  ¶
Pull the screen out gently Lay the screen down on the keyboard
Step 5  ¶
  • Pull the screen out gently
  • Lay the screen down on the keyboard
Step 6  ¶
Locate the connector between the screen and the computer Remove any tape
Step 6  ¶
  • Locate the connector between the screen and the computer
  • Remove any tape
Step 7  ¶
Gently pull the connector off of the screen
Step 7  ¶
  • Gently pull the connector off of the screen
  • The screen can now be replaced with a new one
