Help
Samsung Galaxy Note5 Display Assembly Replacement
Follow this guide to remove and replace the display assembly for your Samsung Galaxy Note5.
  • Author: Arthur Shi
  • Time estimate: 1 - 3 hours
  • Difficulty: Difficult
Follow this guide to remove and replace the display assembly for your Samsung Galaxy Note5. The display assembly includes the front glass and the OLED panel.
This guide instructs you to replace only the display while leaving the original frame, logic board, and battery in place. However, some replacement screens for this phone come pre-installed in a new frame (a.k.a. chassis), which requires a very different procedure—transplanting your phone's internals and installing a new battery. Make sure you have the correct part before starting this guide.
Note: If the frame is damaged or bent, it's important to replace it, or else the new screen may not mount correctly and can suffer damage from uneven pressure.
Warning: The process of separating the display from the frame usually destroys the display, so don't follow this guide unless you intend to replace the display.
