Help
HP Chromebook 14-Q070NR Motherboard Replacement
To fix the blue screen of death or any screen problems, just replace the motherboard to restore it.
  • Author: Jose Hernandez
  • Time estimate: 45 minutes
  • Difficulty: Moderate
A motherboard is essentially the brain of a computer, it controls all the components in a computer to function properly without any errors. Use this guide to replace the motherboard of your device.
Step 1 Motherboard  ¶
Carefully remove the (3) three plastic strips attached to the motherboard. Carefully remove the (3) three plastic strips attached to the motherboard. Carefully remove the (3) three plastic strips attached to the motherboard.
  • Carefully remove the (3) three plastic strips attached to the motherboard.
Step 2  ¶
Use the Phillips #1 screwdriver to remove the (5) five screws. Use the Phillips #1 screwdriver to remove the (5) five screws.
Step 2  ¶
  • Use the Phillips #1 screwdriver to remove the (5) five screws.
Step 3  ¶
Use the blue plastic opening tool to disconnect the connectors. Remove the fan from the motherboard. Use the blue plastic opening tool to disconnect the connectors. Remove the fan from the motherboard.
Step 3  ¶
  • Use the blue plastic opening tool to disconnect the connectors. Remove the fan from the motherboard.
Step 4  ¶
Gently lift while using the plastic opening tool to unhinge the motherboard from the computer in an upward pattern. Be very careful not to detach the motherboard to quickly or forcefully since you could damage or break it.
Step 4  ¶
  • Gently lift while using the plastic opening tool to unhinge the motherboard from the computer in an upward pattern.
  • Be very careful not to detach the motherboard to quickly or forcefully since you could damage or break it.
