Help
ZTE Grand X Max Plus Back Cover Replacement
Guide to replace the back cover of the ZTE Grand X Max Plus. Use this guide if you have a cracked back cover and want to replace it.
  • Author: Jordano Baer
  • Time estimate: 20 minutes
  • Difficulty: Moderate
You can use this guide if you have a cracked back cover for your ZTE Grand X Max Plus and want to replace it.
You can also use this as a guide to open your phone.
Step 1 Back Cover  ¶
Make sure you turn off your phone before starting.
Step 1 Back Cover  ¶
  • Make sure you turn off your phone before starting.
  • Heat the phone using a heating pad, heat gun, or hair dryer to loosen the glue. You just need to heat the back of the phone.
  • You can also use a hair dryer or a heating gun for this step.
Step 2  ¶
After the phone is heated, use the blue plastic opening tool on both sides of the phone. Don't apply too much pressure because the cover can crack easily.
Step 2  ¶
  • After the phone is heated, use the blue plastic opening tool on both sides of the phone.
  • Don't apply too much pressure because the cover can crack easily.
  • To avoid that your cover cracks, you can add tape to back cover.
  • You can use a suction cup to help remove the battery.
Step 3  ¶
Carefully remove the cover from the phone. Carefully remove the cover from the phone.
Step 3  ¶
  • Carefully remove the cover from the phone.
