Help
Eureka SuctionSeal 2.0 Pet Motor Replacement
How to replace the Eureka SuctionSeal 2.0 Pet motor.
This guide walks you through removing the Eureka SuctionSeal 2.0 Pet vacuum's motor. You may find this guide useful if you are experiencing poor suction. This guide requires physical strength to follow so it is recommended that owners attempt to resolve issues through the troubleshooting page before using this guide.
Step 1 Motor  ¶
Rotate the motor cover upright until you hear the foot pedal click and the cover won't rotate in either direction. Remove the bottom exhaust filter. Use a 3.0 hex bit screwdriver to remove the two 20mm screws on the top of the dust cup stand.
Step 1 Motor  ¶
  • Rotate the motor cover upright until you hear the foot pedal click and the cover won't rotate in either direction.
  • Remove the bottom exhaust filter.
  • Use a 3.0 hex bit screwdriver to remove the two 20mm screws on the top of the dust cup stand.
  • Remove the dust cup stand.
Step 2  ¶
Press the handle release pedal and rotate the motor cover downward until it is fully reclined. Press the handle release pedal and rotate the motor cover downward until it is fully reclined.
Step 2  ¶
  • Press the handle release pedal and rotate the motor cover downward until it is fully reclined.
Step 3  ¶
Use a 3.0 hex bit screwdriver to remove the three 20mm screws on the front of the motor cover. The screw holes will only be visible if the motor cover is rotated completely downward.
Step 3  ¶
  • Use a 3.0 hex bit screwdriver to remove the three 20mm screws on the front of the motor cover.
  • The screw holes will only be visible if the motor cover is rotated completely downward.
Step 4  ¶
Flip the vacuum over so that the underside of the device is facing upward. Use a 3.0 Hex bit screwdriver to remove the two 20mm screws on the bottom of the motor cover.
Step 4  ¶
  • Flip the vacuum over so that the underside of the device is facing upward.
  • Use a 3.0 Hex bit screwdriver to remove the two 20mm screws on the bottom of the motor cover.
  • The two screw holes will only be accessible if the handle release pedal is still released and the motor cover is rotated downward.
Step 5  ¶
Flip the vacuum so that it is right side up again  with the front of the motor cover facing you. Insert either a metal spudger or a plastic opening tool into the right or left side of the cover seam.
Step 5  ¶
  • Flip the vacuum so that it is right side up again with the front of the motor cover facing you.
  • Insert either a metal spudger or a plastic opening tool into the right or left side of the cover seam.
  • Pry upward as you move the tool across the cover, separating the top half of the motor cover from the lower half.
  • There will be some audible popping noises from separating the cover.
Step 6  ¶
Grip the exhaust valve at the top of the motor cover. Lift up on the left side of the exhaust valve and then pull the right side upward to pry apart the motor cover.
Step 6  ¶
  • Grip the exhaust valve at the top of the motor cover.
  • Lift up on the left side of the exhaust valve and then pull the right side upward to pry apart the motor cover.
  • Separating the cover takes a firm pull. You may need someone to assist you in pulling the cover apart.
  • When you remove the cover, make sure to keep the cover close to the motor. There is a short wire that connects the top of the cover to the motor. The wire can be damaged if the cover is separated too far.
Step 7  ¶
Make sure the vacuum is unplugged before touching any internal components. Grip the white cable that connects the power switch to the motor. Get as close as possible to the motor connection. Pull firmly to separate the cable from the motor.
Step 7  ¶
  • Make sure the vacuum is unplugged before touching any internal components.
  • Grip the white cable that connects the power switch to the motor. Get as close as possible to the motor connection.
  • Pull firmly to separate the cable from the motor.
Step 8  ¶
There is a black wire that connects the cover to the motor. Be careful to keep this wire connected and undamaged while removing the motor. Lift up on the left side of the motor. Move the motor to the left, sliding the motor shaft out of its circular casing.
Step 8  ¶
  • There is a black wire that connects the cover to the motor. Be careful to keep this wire connected and undamaged while removing the motor.
  • Lift up on the left side of the motor.
  • Move the motor to the left, sliding the motor shaft out of its circular casing.
  • Separate the motor completely from the vacuum's base.
