Help
Eureka SuctionSeal 2.0 Pet Brush Roll Belt Replacement
How to replace the Eureka SuctionSeal 2.0 Pet brush roll belt.
This guide walks you through the replacement of the Eureka SuctionSeal 2.0 Pet Brush Roll Belt. A damaged brush roll is a common occurrence and can create several problems, making this a useful troubleshooting guide.
Tools
Step 1 Brush Roll Belt  ¶
Rotate the belt until the front is above the motor shaft. Twist the belt away from you, allowing the narrow side of the belt to slip between the motor shaft and the vertical rod. Separate the belt from the motor shaft.
  • Rotate the belt until the front is above the motor shaft.
  • Twist the belt away from you, allowing the narrow side of the belt to slip between the motor shaft and the vertical rod.
  • Separate the belt from the motor shaft.
