Help
Sony Vaio Fit 13A SVF13NA1EL Fan Replacement
Confusing Text
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Before deciding your fan needs to be replaced, check the fan and vents for dust. If cleaning them was not successful, replacement may be necessary.
  • Author: Olivia
  • Time estimate: 15 minutes
  • Difficulty: Moderate
Laptop overheating? Fan making a lot of noise ? A fan replacement may be what you need.
Step 1 Fan  ¶
Begin by turning the laptop top-down on a flat surface.
Step 1 Fan  ¶
  • Begin by turning the laptop top-down on a flat surface.
  • JIS #1 screwdriver to remove the 4 screws circled in red from the back cover
  • Use a JIS #0 screwdriver to remove the 8 screws circled in orange
  • Many of these screws are located underneath the rubber pads on the device.
  • Keep track of the locations of the screws removed for ease of reassembly.
Step 2  ¶
Use a spudger to help carefully remove the back cover from the laptop.
Step 2  ¶
  • Use a spudger to help carefully remove the back cover from the laptop.
  • Be careful when around the ports and headphone jack to avoid causing damage to these components.
Step 3  ¶
Lift up back cover to access internal components of the laptop Lift up back cover to access internal components of the laptop
Step 3  ¶
  • Lift up back cover to access internal components of the laptop
Step 4  ¶
Gently dab isopropyl alcohol on a microfiber cloth and gently clean the fan blades before deciding it needs to be replaced.
Step 4  ¶
  • Gently dab isopropyl alcohol on a microfiber cloth and gently clean the fan blades before deciding it needs to be replaced.
  • Follow the previous steps in reverse order to reassemble and test if the problem is solved.
Step 5  ¶
If cleaning the fan does not work follow steps 1-3 to remove the back cover of the laptop.
Step 5  ¶
  • If cleaning the fan does not work follow steps 1-3 to remove the back cover of the laptop.
  • Pull back the pieces of tape, and remove the 3 screws around the fan (red)
  • Remove the 3 screws surrounding the attached heat sink (orange) with the screwdriver.
Step 6  ¶
With the aid of a a spudger, carefully unplug the fan connector With the aid of a a spudger, carefully unplug the fan connector
Step 6  ¶
  • With the aid of a a spudger, carefully unplug the fan connector
