Help
LG V20 MB Assembly Replacement
Prerequisite Only
Prerequisite Only
Please note that this guide is only a prerequisite for other guides.
This motherboard replacement guide will help bring your phone back to life.
  • Author: Max Wu
  • Time estimate: 10 minutes
  • Difficulty: Moderate
Replacing your motherboard can help solve a variety of issues that might seem to pop up on your phone. Not turning on? Blue screen? Random restarting? All of these symptoms can be a result of a faulty motherboard. This guide will show you how to properly replace the motherboard to restore your phone.
Step 1 Motherboard Assembly  ¶
Use the flat end of a spudger to disconnect the flex cable of the left rear camera.
  • Use the flat end of a spudger to disconnect the flex cable of the left rear camera.
  • The second rear camera will come out with the motherboard since it is connected on the other side.
  • You can leave the front facing camera in its place as long as you're careful while removing the motherboard assembly. However if you feel uncertain, carefully remove it with a pair of tweezers.
Step 2  ¶
Disconnect the display flex cable with the flat end of a spudger.
Step 2  ¶
  • Disconnect the display flex cable with the flat end of a spudger.
Step 3  ¶
Use the pointed end of a spudger to lift up the motherboard assembly until you can get a good grip. Carefully lift up the motherboard assembly and remove it.
Step 3  ¶
  • Use the pointed end of a spudger to lift up the motherboard assembly until you can get a good grip.
  • Carefully lift up the motherboard assembly and remove it.
