Help
Nikon Coolpix 7900 Back Cover Replacement
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
To outline the process for removing the back cover of the Nikon Coolpix 7900.
  • Author: Kaky Payne
  • Time estimate: 15 minutes
  • Difficulty: Moderate
Use this guide to replace the back cover.
Tools
Relevant Parts
Step 1 Back Cover  ¶
Remove the four 3.0mm screws on the bottom of the camera.
Step 1 Back Cover  ¶
  • Remove the four 3.0mm screws on the bottom of the camera.
Step 2  ¶
Remove the two 3.0mm screws on the left side of the camera near the memory card compartment.
Step 2  ¶
  • Remove the two 3.0mm screws on the left side of the camera near the memory card compartment.
Step 3  ¶
Remove the two 3.0mm screws on the right side of the camera.
Step 3  ¶
  • Remove the two 3.0mm screws on the right side of the camera.
Step 4  ¶
Carefully open the back cover. Take care as there are connectors still attached.
Step 4  ¶
  • Carefully open the back cover. Take care as there are connectors still attached.
Step 5  ¶
Disconnect the cable by pulling the head upward along the green circuit board. If you only are changing the LCD, skip this step.
Step 5  ¶
  • Disconnect the cable by pulling the head upward along the green circuit board. If you only are changing the LCD, skip this step.
Step 6  ¶
Disconnect the ribbon cable by grabbing the two handles and pulling it directly out of the socket. If you are only changing LCD, skip this step.
Step 6  ¶
  • Disconnect the ribbon cable by grabbing the two handles and pulling it directly out of the socket. If you are only changing LCD, skip this step.
  • The back cover will be disconnected from the camera
