Help
LG V20 Loudspeaker Replacement
This is a replacement guide for the audio loudspeaker on the LG V20.
  • Author: Elliot Mumma
  • Time estimate: 10 - 15 minutes
  • Difficulty: Moderate
Are you tired of your LG V20 plying music that sounds distorted or is barely audible? The main speaker may be disconnected or damaged and require replacement. This guide will explain the steps needed to replace the speaker.
Sections
Step 1 Loudspeaker  ¶
The loudspeaker is attached to the cover of the motherboard by a tight plastic clamp. Flip the motherboard cover and pull the loudspeaker out of the plastic clamp at the lower end of it. Take care not to break the clamp.
  • The loudspeaker is attached to the cover of the motherboard by a tight plastic clamp.
  • Flip the motherboard cover and pull the loudspeaker out of the plastic clamp at the lower end of it. Take care not to break the clamp.
