Help
Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement
This guide will replace the motherboard in the Acer Chromebook R11 CB5-132T-C1LK.
Replacing a motherboard is usually a last resort option as the motherboard is where all the data and files are in a Chromebook. Only replace a Chromebook motherboard if you are certain it is a motherboard that is malfunctioning.
Tools (continued)
Relevant Parts
Step 1 Motherboard  ¶
Orient the laptop so the motherboard side is further away from you in a landscape position. Use the flat end of the spudger to lift the the ZIF connector retaining flaps securing the three small ribbon cables.
  • Orient the laptop so the motherboard side is further away from you in a landscape position.
  • Use the flat end of the spudger to lift the the ZIF connector retaining flaps securing the three small ribbon cables.
Step 2  ¶
Pull out the locking mechanism of the  touchpad ZIF connector with the narrow end of the spudger.
Step 2  ¶
  • Pull out the locking mechanism of the touchpad ZIF connector with the narrow end of the spudger.
Step 3  ¶
Using tweezers, pull the five ribbon cables near the bottom of the motherboard  from their sockets. Using tweezers,  pull the single cable near the top left  of the motherboard  from its socket. Using tweezers,  pull the single cable near the top left  of the motherboard  from its socket.
Step 3  ¶
  • Using tweezers, pull the five ribbon cables near the bottom of the motherboard from their sockets.
  • Using tweezers, pull the single cable near the top left of the motherboard from its socket.
Step 4  ¶
Remove the screen connector from the motherboard by pulling directly upward on the black tabs.
Step 4  ¶
  • Remove the screen connector from the motherboard by pulling directly upward on the black tabs.
Step 5  ¶
Remove the 2.0 mm screw from the Wi-Fi card.
Step 5  ¶
  • Remove the 2.0 mm screw from the Wi-Fi card.
Step 6  ¶
Slide the Wi-Fi card out from the port with tweezers.
Step 6  ¶
  • Slide the Wi-Fi card out from the port with tweezers.
Step 7  ¶
Remove the two 4.5 mm screws and a 2.0 mm screw from the middle of the motherboard.
Step 7  ¶
  • Remove the two 4.5 mm screws and a 2.0 mm screw from the middle of the motherboard.
Step 8  ¶
Unscrew the two 4.5 mm screws from the top right metal tab connected to the motherboard. Lift the right corner upward to  remove the metal tabs from the motherboard
Step 8  ¶
  • Unscrew the two 4.5 mm screws from the top right metal tab connected to the motherboard.
  • Lift the right corner upward to remove the metal tabs from the motherboard
Step 9  ¶
Lift the motherboard upward to completely remove it from the base.
Step 9  ¶
  • Lift the motherboard upward to completely remove it from the base.
