Help
LG V20 Primary Rear-Facing Camera Replacement
This guide will show you how to replace the primary rear-facing camera in the LG V20.
  • Author: Garrett Janney
  • Time estimate: 10 - 15 minutes
  • Difficulty: Moderate
Are all your photos on the LG V20 coming out blurry? There is probably an issue with the rear-facing camera. This guide will take you through the steps required to remove the camera.
Step 1 Primary Rear-Facing Camera  ¶
Flip the motherboard assembly and use the flat end of a spudger to carefully disconnect the flex cable of the rear camera. Use a pair of tweezers to remove the rear camera.
  • Flip the motherboard assembly and use the flat end of a spudger to carefully disconnect the flex cable of the rear camera.
  • Use a pair of tweezers to remove the rear camera.
