Help
MSI GT72 2QE Dominator Pro RAM Replacement
This guide will lead the viewer through the steps of removing the laptop's RAM.
  • Author: Nate
  • Time estimate: 5 minutes
  • Difficulty: Easy
Want to replace your RAM? This guide will show all the steps you need to remove your old one.
Step 1 RAM  ¶
Remove the 7 indicated 6mm Phillips #00 screws.
Step 1 RAM  ¶
  • Remove the 7 indicated 6mm Phillips #00 screws.
  • Same PH0 screwdriver can be used in all steps.
Step 2  ¶
With the screws out, remove the  bottom door.
Step 2  ¶
  • With the screws out, remove the bottom door.
Step 3  ¶
Pull back clamps holding the RAM to remove it from the socket. Pull back clamps holding the RAM to remove it from the socket.
Step 3  ¶
  • Pull back clamps holding the RAM to remove it from the socket.
