Help
Bowers and Wilkins T7 Battery Replacement
Replace the battery for a Bowers and Wilkins T7 Bluetooth Speaker.
Use this guide to learn how to replace your battery for the Bowers and Wilkins T7 Bluetooth Speaker.
Sections
Tools
Step 1 Battery  ¶
Using a cutting tool such as a Jimmy steel blade or wire cutter, cut the cable tie surrounding the battery.
Step 1 Battery  ¶
  • Using a cutting tool such as a Jimmy steel blade or wire cutter, cut the cable tie surrounding the battery.
  • Be careful not to damage the battery while cutting the cable tie surrounding the battery.
Step 2  ¶
Using the ifixit Opening Tool,  pry out the battery power supply connector. Pull and remove the battery power supply connector.
Step 2  ¶
  • Using the ifixit Opening Tool, pry out the battery power supply connector.
  • Pull and remove the battery power supply connector.
Step 3  ¶
After disconnecting the power supply connector, pull the battery out of its case. After disconnecting the power supply connector, pull the battery out of its case.
Step 3  ¶
  • After disconnecting the power supply connector, pull the battery out of its case.
