Help
Unbranded UB-15MS10 Power Button Replacement
Markup Mishap
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Slice and Dice
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
This guide is for replacing the actual power button on the internal motherboard and replacing the plastic external power button.
Step 1 Power Button  ¶
Use an opening tool to pry off the memory card door located on the back of the tablet. Use an opening tool to pry off the memory card door located on the back of the tablet. Use an opening tool to pry off the memory card door located on the back of the tablet.
  • Use an opening tool to pry off the memory card door located on the back of the tablet.
Step 2  ¶
Remove the two 1.2mm screws found under the memory card door.
Step 2  ¶
  • Remove the two 1.2mm screws found under the memory card door.
Step 3  ¶
Pry around the outside carefully using the black spudger to get in. Putting many opening tools around the edge helps keep it from sealing shut again. Pry around the outside carefully using the black spudger to get in. Putting many opening tools around the edge helps keep it from sealing shut again. Pry around the outside carefully using the black spudger to get in. Putting many opening tools around the edge helps keep it from sealing shut again.
Step 3  ¶
  • Pry around the outside carefully using the black spudger to get in. Putting many opening tools around the edge helps keep it from sealing shut again.
Step 4  ¶
Remove the ribbon cable by using the black spudger to release the tab and carefully pull out the ribbon cable. Remove the ribbon cable by using the black spudger to release the tab and carefully pull out the ribbon cable.
Step 4  ¶
  • Remove the ribbon cable by using the black spudger to release the tab and carefully pull out the ribbon cable.
Step 5  ¶
Peel up the grey tape so that you can get to the board and untape the ribbon cable that was removed from the motherboard in the previous step. Peel up the grey tape so that you can get to the board and untape the ribbon cable that was removed from the motherboard in the previous step. Peel up the grey tape so that you can get to the board and untape the ribbon cable that was removed from the motherboard in the previous step.
Step 5  ¶
  • Peel up the grey tape so that you can get to the board and untape the ribbon cable that was removed from the motherboard in the previous step.
Step 6  ¶
Remove the two 1.2mm screws from the board. Remove the two 1.2mm screws from the board.
Step 6  ¶
  • Remove the two 1.2mm screws from the board.
Step 7  ¶
Use an opening tool to remove the board from the case.
Step 7  ¶
  • Use an opening tool to remove the board from the case.
Step 8  ¶
Detach the three ribbon cables using spudger in the first picture. Then cut the black, white, and red wires shown in picture two. Detach the three ribbon cables using spudger in the first picture. Then cut the black, white, and red wires shown in picture two.
Step 8  ¶
  • Detach the three ribbon cables using spudger in the first picture. Then cut the black, white, and red wires shown in picture two.
Step 9  ¶
Check to see if plastic power button is broken. If broken, replace with new plastic power button. Rebuild device by doing steps 1-8 in reverse order and see if your power button is working. If the device still does not turn on, follow steps 1-8 and skip this step.
Step 9  ¶
  • Check to see if plastic power button is broken. If broken, replace with new plastic power button. Rebuild device by doing steps 1-8 in reverse order and see if your power button is working. If the device still does not turn on, follow steps 1-8 and skip this step.
Step 10  ¶
Unscrew the two 1.2mm screws of this component, which is wired to the motherboard.
Step 10  ¶
  • Unscrew the two 1.2mm screws of this component, which is wired to the motherboard.
Step 11  ¶
Unscrew the two 1.2mm screws of this component, which is also wired to the motherboard.
Step 11  ¶
  • Unscrew the two 1.2mm screws of this component, which is also wired to the motherboard.
Step 12  ¶
Remove old motherboard from tablet. Take the new motherboard and splice the black wire of the board to the black wire of the battery. Do the same for the white and red wires.
Step 12  ¶
  • Remove old motherboard from tablet. Take the new motherboard and splice the black wire of the board to the black wire of the battery. Do the same for the white and red wires.
