Help
PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement
Member-Contributed Guide
Replace the battery on PowerBeats2 Wireless Headphones by Dr. Dre
  • Author: Faizan Naveed
  • Time estimate: 30 minutes
  • Difficulty: Moderate
Step 1 Locate Battery.  ¶
The battery is located inside the right side ear piece.
  • The battery is located inside the right side ear piece.
Step 2 Heat Right Side.  ¶
Heat the right side gently at 140 F for about 3 minutes.
  • Heat the right side gently at 140 F for about 3 minutes.
  • Do not over heat or it will melt the housing.
Step 3 Remove Battery Cover/Casing  ¶
After heating, gently remove the cover/casing as shown in the picture. Take your time and re-heat if cover/casing does not remove smoothly.
  • After heating, gently remove the cover/casing as shown in the picture.
  • Take your time and re-heat if cover/casing does not remove smoothly.
Step 4 Desolder & Replace Battery  ¶
Desolder battery using soldering iron and replace with replacement battery.
  • Desolder battery using soldering iron and replace with replacement battery.
Step 5 Reattach Battery Cover/Casing  ¶
After battery is replaced, apply super glue to the border of the inside of the battery cover/casing and put it back in place. Use small clamps/binder clip to hold the housing in place while the super glue dries up.
  • After battery is replaced, apply super glue to the border of the inside of the battery cover/casing and put it back in place.
  • Use small clamps/binder clip to hold the housing in place while the super glue dries up.
