Help
SodaStream Source Internal Disassembly
Prerequisite Only
Prerequisite Only
Please note that this guide is only a prerequisite for other guides.
Prerequisite Only
Step 1 SodaStream Source Internal Disassembly  ¶
Push the gold bar, located in the top of the device, out of the carbonating block. You can use the end of your screwdriver to push this piece out. You can use the end of your screwdriver to push this piece out.
  • Push the gold bar, located in the top of the device, out of the carbonating block.
  • You can use the end of your screwdriver to push this piece out.
Step 2  ¶
Slide the yellow battery cover up and away to remove it from the device. Slide the yellow battery cover up and away to remove it from the device. Slide the yellow battery cover up and away to remove it from the device.
Step 2  ¶
  • Slide the yellow battery cover up and away to remove it from the device.
Step 3  ¶
Unhook the bottom piece of the plastic arm on each side of the device. Unhook the bottom piece of the plastic arm on each side of the device.
Step 3  ¶
  • Unhook the bottom piece of the plastic arm on each side of the device.
Step 4  ¶
Lift the top of the plastic arm with the spudger and remove it on both sides. Lift the top of the plastic arm with the spudger and remove it on both sides.
Step 4  ¶
  • Lift the top of the plastic arm with the spudger and remove it on both sides.
Step 5  ¶
Remove the plastic piece, located near the front of the carbonating block, from both sides of the device using a plastic opening tool or nylon spudger. Remove the plastic piece, located near the front of the carbonating block, from both sides of the device using a plastic opening tool or nylon spudger.
Step 5  ¶
  • Remove the plastic piece, located near the front of the carbonating block, from both sides of the device using a plastic opening tool or nylon spudger.
Step 6  ¶
Remove the plastic oval and the spring within it. Remove the plastic oval and the spring within it.
Step 6  ¶
  • Remove the plastic oval and the spring within it.
Step 7  ¶
Pull the loader tab cover down and away from the rest of the carbonating block. Pull the loader tab cover down and away from the rest of the carbonating block.
Step 7  ¶
  • Pull the loader tab cover down and away from the rest of the carbonating block.
Step 8  ¶
Remove the three 17.9 mm screws located on the right side.
Step 8  ¶
  • Remove the three 17.9 mm screws located on the right side.
  • These screws may be difficult to access.
Step 9  ¶
Unhook the four clips on the top of the carbonating block and remove the plastic cover. Unhook the four clips on the top of the carbonating block and remove the plastic cover.
Step 9  ¶
  • Unhook the four clips on the top of the carbonating block and remove the plastic cover.
Step 10  ¶
Lift the clips located on both sides with the plastic spudger. Slide the front cover off. Lift the clips located on both sides with the plastic spudger. Slide the front cover off. Lift the clips located on both sides with the plastic spudger. Slide the front cover off.
Step 10  ¶
  • Lift the clips located on both sides with the plastic spudger. Slide the front cover off.
Step 11  ¶
Unhook the silver spring arms on both sides of the device by pushing down. Unhook the silver spring arms on both sides of the device by pushing down.
Step 11  ¶
  • Unhook the silver spring arms on both sides of the device by pushing down.
Step 12  ¶
Grip the right and left sides of the device and pull it into two identical halves.
Step 12  ¶
  • Grip the right and left sides of the device and pull it into two identical halves.
  • Once these two pieces are apart, all remaining internal components will fall out of the device.
Step 13  ¶
Pull the foam pad up and remove it from the front side of the carbonation component. Pull the foam pad up and remove it from the front side of the carbonation component. Pull the foam pad up and remove it from the front side of the carbonation component.
Step 13  ¶
  • Pull the foam pad up and remove it from the front side of the carbonation component.
Step 14  ¶
Remove the six 17.7 mm screws from the underside of the loader tab piece.
Step 14  ¶
  • Remove the six 17.7 mm screws from the underside of the loader tab piece.
Step 15  ¶
Pull the loader tab out of  the nozzle. Pull the loader tab out of  the nozzle. Pull the loader tab out of  the nozzle.
Step 15  ¶
  • Pull the loader tab out of the nozzle.
