Help
Pacific Image Electronics CS3600 Screen Replacement
Needs Better Images
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Missing Details
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
How to replace the viewing screen on a Pacific Electronics CS3600 Scanner.
This guide will show you have to remove the viewing screen from the front of the scanner if the screen breaks, or is no longer transparent.
Tools
Step 1 Screen  ¶
To start, open the device by removing the 5, 5mm x 9mm screws, with a J1 screwdriver.
Step 1 Screen  ¶
  • To start, open the device by removing the 5, 5mm x 9mm screws, with a J1 screwdriver.
Step 2  ¶
With light force, open the scanner at the seam.
Step 2  ¶
  • With light force, open the scanner at the seam.
Step 3  ¶
Push the screen away from the scanner from the inside with light force until it is no longer attached. Replace with a new screen.
Step 3  ¶
  • Push the screen away from the scanner from the inside with light force until it is no longer attached.
  • Replace with a new screen.
