Help
Pacific Image Electronics CS3600 Motor Replacement
Needs Better Images
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Missing Details
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Remove and replace the scanner's motor.
If you find that your scanner is making strange noises or still fails to function properly, the motor might be jammed or need replacing. This guide will help you remove the motor from the inner casing.
Step 1 Motor  ¶
To start, open the device by removing the 5, 5mm x 9mm screws, with a Phillips J1 screwdriver. To start, open the device by removing the 5, 5mm x 9mm screws, with a Phillips J1 screwdriver.
Step 1 Motor  ¶
  • To start, open the device by removing the 5, 5mm x 9mm screws, with a Phillips J1 screwdriver.
Step 2  ¶
Next, remove the 5 9mm x 5mm screws from the circled spots with a Phillips J1 screwdriver.
Step 2  ¶
  • Next, remove the 5 9mm x 5mm screws from the circled spots with a Phillips J1 screwdriver.
Step 3  ¶
Once the screws are removed, carefully lift the motor casing out of the device.
Step 3  ¶
  • Once the screws are removed, carefully lift the motor casing out of the device.
  • The plastic piece circled acts as a clamp, lift the casing up and towards you to detach the casing.
Step 4  ¶
Now, with the motor casing in hand, remove  the two 9mm x 5mm screw and washer at the top of the motor casing using a J1 screwdriver. Gently pull the motor away from the casing to expose the wires.
Step 4  ¶
  • Now, with the motor casing in hand, remove the two 9mm x 5mm screw and washer at the top of the motor casing using a J1 screwdriver.
  • Gently pull the motor away from the casing to expose the wires.
Step 5  ¶
Carefully desolder the wires from their contact point on the circuit board.
Step 5  ¶
  • Carefully desolder the wires from their contact point on the circuit board.
  • You have now successfully removed the motor!
