Help
Panasonic ARC ES-LT3N Power Button Replacement
Replace your power button and bring back efficient performance to your Panasonic ARC ES-LT3N .
  • Author: Andrew Trainor
  • Time estimate: 15 minutes
  • Difficulty: Moderate
This repair guide will show you the best step by step procedure of how to replace your power button in your Panasonic ARC ES-LT3N. The process is fairly easy and you only need a one tool!
Step 1 Power Button  ¶
Remove the 8 mm screws directly below the lock switch. Remove the 8 mm screws directly below the lock switch. Remove the 8 mm screws directly below the lock switch.
  • Remove the 8 mm screws directly below the lock switch.
Step 2  ¶
Push the lock switch upward and remove the 6 mm screw hidden beneath. Push the lock switch upward and remove the 6 mm screw hidden beneath. Push the lock switch upward and remove the 6 mm screw hidden beneath.
Step 2  ¶
  • Push the lock switch upward and remove the 6 mm screw hidden beneath.
Step 3  ¶
Remove the lock switch by sliding it downward until it is  out of place. Remove the lock switch by sliding it downward until it is  out of place.
Step 3  ¶
  • Remove the lock switch by sliding it downward until it is out of place.
Step 4  ¶
Starting from the bottom, lift the front casing upward to separate the case from the device. Continue to lift the device upward until you can pull the casing off. It may take some wiggling or slight bending of the plastic to remove all the way.
Step 4  ¶
  • Starting from the bottom, lift the front casing upward to separate the case from the device.
  • Continue to lift the device upward until you can pull the casing off.
  • It may take some wiggling or slight bending of the plastic to remove all the way.
Step 5  ¶
Remove the button. Remove the button. Remove the button.
Step 5  ¶
  • Remove the button.
