Help
Panasonic ARC ES-LT3N Inner Blades Replacement
Replace your inner blades and bring back efficient performance to your Panasonic ARC ES-LT3N .
  • Author: Andrew Trainor
  • Time estimate: 2 minutes
  • Difficulty: Very easy
This repair guide will show you the best step by step procedure of how to replace your inner blades in your Panasonic ARC ES-LT3N. The process is very easy!
Sections
Step 1 Inner Blades  ¶
Do not touch the top part of the blades, you may cut yourself Pinch the sides of the inner blades and pull upward to remove
  • Do not touch the top part of the blades, you may cut yourself
  • Pinch the sides of the inner blades and pull upward to remove
