Help
Roku 4 Remote Control Buttons Replacement
This replacement guide is for replacing the buttons on your Roku 4 remote control.
  • Author: Hank Harrison
  • Time estimate: 5 - 8 minutes
  • Difficulty: Easy
The remote control is a device that will help you control your Roku 4 from a distance without having to directly interact with the device. This guide will help you replace the buttons on your remote control.
Step 1 Remote Control Buttons  ¶
Remove the three plastic sheets from the rubber button panels by gripping one edge of the sheet and pulling upward.
  • Remove the three plastic sheets from the rubber button panels by gripping one edge of the sheet and pulling upward.
Step 2  ¶
Remove the button panels by gripping the bottom edge and pulling upward until the panel is no longer in contact with the remote cover. Remove the button panels by gripping the bottom edge and pulling upward until the panel is no longer in contact with the remote cover. Remove the button panels by gripping the bottom edge and pulling upward until the panel is no longer in contact with the remote cover.
Step 2  ¶
  • Remove the button panels by gripping the bottom edge and pulling upward until the panel is no longer in contact with the remote cover.
