Help
Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement
This page will help you replace the motherboard for the Samsung Galaxy Tab E Lite 7 Kids
  • Author: Nicholas Nolan
  • Time estimate: 15 - 20 minutes
  • Difficulty: Moderate
This replacement guide will show you how to replace the motherboard in your Samsung Galaxy Tab E Lite 7 Kids. You will need to follow the instructions carefully as to not damage any fragile components in your tablet.
Step 1 Motherboard  ¶
Use the plastic opening tool to lift up the black ZIF (zero insertion force) connector. Use your hands to pull the black cable out of its slot. Use your hands to pull the black cable out of its slot.
  • Use the plastic opening tool to lift up the black ZIF (zero insertion force) connector.
  • Use your hands to pull the black cable out of its slot.
Step 2  ¶
Use the plastic opening tool to lift the ZIF (zero insertion force) connector holding the ribbon cable. Pull out the battery's ribbon cable.
Step 2  ¶
  • Use the plastic opening tool to lift the ZIF (zero insertion force) connector holding the ribbon cable.
  • Pull out the battery's ribbon cable.
Step 3  ¶
Use the plastic opening tool to lift up the latch to the ribbon cable. Remove the ribbon cable from the connector.
Step 3  ¶
  • Use the plastic opening tool to lift up the latch to the ribbon cable.
  • Remove the ribbon cable from the connector.
Step 4  ¶
Remove the seven 4mm PH000 screws holding the motherboard in place.
Step 4  ¶
  • Remove the seven 4mm PH000 screws holding the motherboard in place.
Step 5  ¶
Use the plastic opening tool to pry up the tab holding the motherboard in place.
Step 5  ¶
  • Use the plastic opening tool to pry up the tab holding the motherboard in place.
Step 6  ¶
Use the precision tweezers to remove the black plastic corner on top of the motherboard. Use the plastic opening tool to pull the motherboard out of the case. Use the plastic opening tool to pull the motherboard out of the case.
Step 6  ¶
  • Use the precision tweezers to remove the black plastic corner on top of the motherboard.
  • Use the plastic opening tool to pull the motherboard out of the case.
