Help
SodaStream Source External Disassembly
Prerequisite Only
Prerequisite Only
Please note that this guide is only a prerequisite for other guides.
Prerequisite Only
  • Author: Hailey Smith
  • Time estimate: 4 - 5 minutes
  • Difficulty: Easy
Step 1 SodaStream Source External Disassembly  ¶
Remove the soda bottle and the CO2 canister from the machine. Remove the soda bottle and the CO2 canister from the machine. Remove the soda bottle and the CO2 canister from the machine.
  • Remove the soda bottle and the CO2 canister from the machine.
Step 2  ¶
Remove the four 17.8 mm screw from the bottom metal base using a Phillips #1 screwdriver. Remove the four 17.8 mm screw from the bottom metal base using a Phillips #1 screwdriver.
Step 2  ¶
Step 3  ¶
Pull the outer cover away from the front of the device. Pull the outer cover away from the front of the device.
Step 3  ¶
  • Pull the outer cover away from the front of the device.
Step 4  ¶
Remove the two 18.2 mm screws  from the bottom of the front cover using a Phillips #1 screwdriver.
Step 4  ¶
Step 5  ¶
Firmly pull the front cover off. This piece is difficult to remove and requires force. It may help to use a wide, thin object to pry it off (like a Jimmy).
Step 5  ¶
  • Firmly pull the front cover off.
  • This piece is difficult to remove and requires force. It may help to use a wide, thin object to pry it off (like a Jimmy).
