Help
MacBook Air Models A1237 and A1304 Display Assembly Replacement
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
  • Author: Walter Galan
  • Time estimate: 1 - 2 hours
  • Difficulty: Difficult
Use this guide to replace a broken display.
Step 1 Display Assembly  ¶
Remove the two following screws securing the AirPort/Bluetooth board bracket to the upper case:
  • Remove the two following screws securing the AirPort/Bluetooth board bracket to the upper case:
  • One 4.7 mm Phillips.
  • One 3.9 mm Phillips.
Step 2  ¶
Lift the AirPort/Bluetooth bracket out of the upper case.
Step 2  ¶
  • Lift the AirPort/Bluetooth bracket out of the upper case.
Step 3  ¶
Use a spudger to pry the three antenna cables up off the AirPort/Bluetooth board.
Step 3  ¶
  • Use a spudger to pry the three antenna cables up off the AirPort/Bluetooth board.
Step 4  ¶
Peel the antenna cables up off the adhesive securing them to the upper case.
Step 4  ¶
  • Peel the antenna cables up off the adhesive securing them to the upper case.
Step 5  ¶
Remove the single Phillips screw securing the microphone cable ground loop to the upper case.
Step 5  ¶
  • Remove the single Phillips screw securing the microphone cable ground loop to the upper case.
Step 6  ¶
Remove the following 15 screws:
Step 6  ¶
  • Remove the following 15 screws:
  • Thirteen 2.3 mm Phillips.
  • Two T6 Torx.
  • Leave one T6 Torx screw in each side of the display bracket.
Step 7  ¶
Open the Air so the display is perpendicular to the upper case and place it on a table as shown.
Step 7  ¶
  • Open the Air so the display is perpendicular to the upper case and place it on a table as shown.
  • While holding the top of the Air with one hand, remove the T6 Torx screw from the lower display bracket.
Step 8  ¶
Be sure to hold the Air together while you remove the last Torx screw. Failure to do so may cause the display/upper case to fall, potentially damaging both components.
Step 8  ¶
  • Be sure to hold the Air together while you remove the last Torx screw. Failure to do so may cause the display/upper case to fall, potentially damaging both components.
  • Remove the T6 Torx screw from the upper display bracket.
Step 9  ¶
Pull the upper case straight away from the display, minding any cables that may get caught.
Step 9  ¶
  • Pull the upper case straight away from the display, minding any cables that may get caught.
