Help
Disassembling Sony Cyber-shot DSC-W230 Exterior Case
Bullets!
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Step Trimmer
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Removing the camera's exterior case.
  • Author: Alex
  • Difficulty: Moderate
This guide will explain how to take off the camera's exterior case.
Step 1 Disassembling Sony Cyber-shot DSC-W230 Exterior Case  ¶
Begin by placing the camera upside down and removing the three small center screws.
  • Begin by placing the camera upside down and removing the three small center screws.
  • All screws are the same size and length and can be used interchangably.
Step 2  ¶
Turn the camera on its side (Counterclockwise). Remove the two small screws on either side of the silver panel. Turn the camera 180 degrees onto its other side and remove the two small screws on either side of the silver panel.
Step 2  ¶
  • Turn the camera on its side (Counterclockwise). Remove the two small screws on either side of the silver panel.
  • Turn the camera 180 degrees onto its other side and remove the two small screws on either side of the silver panel.
Step 3  ¶
Locate the camera's tripod mount located on the bottom of the camera. Carefully remove the camera's tripod mount and place it aside. Be careful not to lose this piece.
Step 3  ¶
  • Locate the camera's tripod mount located on the bottom of the camera.
  • Carefully remove the camera's tripod mount and place it aside.
  • Be careful not to lose this piece.
  • Rotate the silver panel labeled 4x clockwise.
