Help
Samsung Level Box Mini Battery Replacement
Battery replacement for the Samsung Level Box Mini.
  • Author: dylan weiss
  • Time estimate: 5 minutes
  • Difficulty: Easy
If the Samsung Level Box Mini is not charging, not turning on, or if the battery is losing power rapidly, then the batteries may require replacement.
Step 1 Battery  ¶
Using a plastic opening tool, go around the edges of the rubber bottom. Insert the same tool under the edge of the rubber and swivel side to side. Continue moving it forward while peeling the plastic off with the precision tweezers. Using a plastic opening tool, go around the edges of the rubber bottom. Insert the same tool under the edge of the rubber and swivel side to side. Continue moving it forward while peeling the plastic off with the precision tweezers.
Step 1 Battery  ¶
  • Using a plastic opening tool, go around the edges of the rubber bottom. Insert the same tool under the edge of the rubber and swivel side to side. Continue moving it forward while peeling the plastic off with the precision tweezers.
Step 2  ¶
Remove the six 4.5 mm Philips #1 screws from the bottom plate using the Screwdriver J00. Take off the bottom plate.
Step 2  ¶
  • Remove the six 4.5 mm Philips #1 screws from the bottom plate using the Screwdriver J00. Take off the bottom plate.
Step 3  ¶
Using the plastic opening tool, remove the batteries from the device.
Step 3  ¶
  • Using the plastic opening tool, remove the batteries from the device.
