Help
Olympus Stylus 760 LCD Screen Replacement
This guide shows how to remove and replace the LCD screen in the Olympus Stylus 760
Step 1 LCD Screen  ¶
Remove the 2 screws from the bottom of the camera
Step 1 LCD Screen  ¶
  • Remove the 2 screws from the bottom of the camera
Step 2  ¶
Using a Phillips head size 0 screwdriver, remove the screw from the right side of the camera
Step 2  ¶
  • Using a Phillips head size 0 screwdriver, remove the screw from the right side of the camera
Step 3  ¶
Remove the 2 screws from the left side of the camera
Step 3  ¶
  • Remove the 2 screws from the left side of the camera
Step 4  ¶
Separate the front casing from the back using a plastic opening tool, gently. Silver band and buttons will become loose when you remove the two pieces. Silver band and buttons will become loose when you remove the two pieces.
Step 4  ¶
  • Separate the front casing from the back using a plastic opening tool, gently.
  • Silver band and buttons will become loose when you remove the two pieces.
Step 5  ¶
Pull the silver bracket off of the camera Pull the silver bracket off of the camera
Step 5  ¶
  • Pull the silver bracket off of the camera
Step 6  ¶
Remove the 4 screws on the inner face of the camera. Circuit ribbon is attached at the top left of the camera. Be careful when separating the front and back of the camera. Pull the camera apart into 2 separate pieces.
Step 6  ¶
  • Remove the 4 screws on the inner face of the camera.
  • Circuit ribbon is attached at the top left of the camera. Be careful when separating the front and back of the camera.
  • Pull the camera apart into 2 separate pieces.
Step 7  ¶
You should be left with 4 large pieces, the outer case, inner lens piece, outer silver band and back case containing the LCD display.
Step 7  ¶
  • You should be left with 4 large pieces, the outer case, inner lens piece, outer silver band and back case containing the LCD display.
Step 8  ¶
Remove 4 screws holding the LCD screen in place. Be cautious of the brackets that come loose when you remove the 3 screws on the right side of the camera
Step 8  ¶
  • Remove 4 screws holding the LCD screen in place.
  • Be cautious of the brackets that come loose when you remove the 3 screws on the right side of the camera
  • LCD Screen is attached to 2 ribbon wires
Step 9  ¶
Pull up on the small ribbon wire to disconnect it from the circuit board Flip the little black clip up to remove the larger ribbon wire from the circuit board.
Step 9  ¶
  • Pull up on the small ribbon wire to disconnect it from the circuit board
  • Flip the little black clip up to remove the larger ribbon wire from the circuit board.
Step 10  ¶
Using a plastic separating tool, remove the LCD screen from the plastic casing.
Step 10  ¶
  • Using a plastic separating tool, remove the LCD screen from the plastic casing.
