Help
MacBook Pro 13" Unibody Mid 2009 Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
We got our hands on a MacBook Pro 13" Unibody and decided to compare it to a MacBook Unibody -- from the inside! Follow us on Twitter to get all the latest updates as we're doing the teardown!
Step 1 MacBook Pro 13" Unibody Mid 2009 Teardown  ¶
Image 1/2: We'll be comparing it to the MacBook Unibody throughout the teardown.
  • This just in: the new MacBook Pro 13" Unibody!
  • We'll be comparing it to the MacBook Unibody throughout the teardown.
    • We have a feeling it will be very similar in most regards.
  • Check out our MacBook Unibody repair guides if you'd like to answer any of your repair-related questions!
  • Would you like to write teardowns like this? Show the world what's inside your gadgets with our new user-contributed teardown platform!
Step 2  ¶
Image 1/1: User's manual
Step 2  ¶
  • Contents of the box:
    • User's manual
    • Restore DVDs
    • 60-watt AC adapter
    • AC adapter extension cable
    • Cleaning cloth
    • No video adapter, as usual.
Step 3  ¶
Image 1/3: No access door for the battery on the bottom.
Step 3  ¶
  • Some comparisons to the MacBook Unibody:
    • No access door for the battery on the bottom.
    • The addition of an SD card slot (and the omission of digital/mic port) is readily apparent.
    • FireWire is back!
    • Computer lock is now on the other side.
    • The SD card sticks out almost .5"! This is a cheeseball design for a MacBook "Pro" if you ask us.
Step 4  ¶
Image 1/2: There's no door latch, going along with the "not user-serviceable battery" theme.
Step 4  ¶
  • Let's get down to business.
  • There's no door latch, going along with the "not user-serviceable battery" theme.
  • We had to dig out a Phillips screwdriver for this step.
  • A quick flip of the lid and...
Step 5  ¶
Image 1/3: The battery compartment is identical to the one we uncovered in the [guide|618|MacBook Pro 17"] Teardown. We'll venture a guess that it looks the same in the updated 15" Pro as well.
Step 5  ¶
  • ...It's almost exactly the same as our old, "lesser" MacBook Unibody.
  • The battery compartment is identical to the one we uncovered in the MacBook Pro 17" Teardown. We'll venture a guess that it looks the same in the updated 15" Pro as well.
  • Remove two tri-wing screws and the battery is suddenly replaceable. The sticker comes right off, just as in the 17" Pro -- because it's adhered to just the battery and midwall, not to the optical drive.
Step 6  ¶
Image 1/3: Model A1322
Step 6  ¶
  • 7-hour battery specifications:
    • Model A1322
    • 10.95V
    • 60Wh
    • "This battery contains no mercury (Hg)."
  • When working on all machines that have internal batteries, disconnect the battery first to cut off power to the entire device.
  • Apple does offer battery replacement service for $129. If you're not near an Apple Store or service provider, you'll be without your machine 3-4 business days.
  • Although the batteries look similar, they're definitely not interchangeable. The MacBook Pro's battery is too large (and different in shape) to fit into the older MacBook Unibody.
Step 7  ¶
Image 1/2: It's still considered user-replaceable by Apple, but replacement does require removing 10 more screws than on the [guide|589|MacBook Unibody|stepid=2953].
Step 7  ¶
  • Removing the hard drive...
  • It's still considered user-replaceable by Apple, but replacement does require removing 10 more screws than on the MacBook Unibody.
  • First thing we'd do is replace the 160 GB Hitachi with something more meaty.
Step 8  ¶
Image 1/2:
Step 8  ¶
  • The subwoofer comes off after removing two screws.
Step 9  ¶
Image 1/2: The brackets and screw layout are identical to the older MacBook Unibody.
Step 9  ¶
  • The optical drive is attached via three Phillips screws.
  • The brackets and screw layout are identical to the older MacBook Unibody.
Step 10  ¶
Image 1/2: It's held in place by adhesive. A quick pry with the spudger will loosen it.
Step 10  ¶
  • Removing the optical drive exposes the right speaker.
  • It's held in place by adhesive. A quick pry with the spudger will loosen it.
Step 11  ¶
Image 1/3:
Step 11  ¶
  • A connector, three Phillips screws, and bam -- the fan's out!
Step 12  ¶
Image 1/3: Remove 7 motherboard screws.
Step 12  ¶
  • Disconnect the LVDS connector.
  • Remove 7 motherboard screws.
  • Remove 2 DC-in screws.
  • Disconnect trackpad, keyboard, and battery level indicator cables.
  • Remove LVDS cable retaining bracket.
  • And the logic board is almost out...
Step 13  ¶
Image 1/2: The logic board is finally free!
Step 13  ¶
  • Pop out the microphone from its cave.
  • The logic board is finally free!
Step 14  ¶
Image 1/2: Like the MacBook Unibody, the heat sink comes out along with the logic board.
Step 14  ¶
  • A couple of images of the logic board, before we strip it naked...
  • Like the MacBook Unibody, the heat sink comes out along with the logic board.
Step 15  ¶
Image 1/2: Hi-res pictures of the [http://s1.guide-images.ifixit.com/igi/W6ZPuEftmbFDbYvb.huge|front] and [http://s1.guide-images.ifixit.com/igi/g2HavWfpJaVTNvjR.huge|back].
Step 15  ¶
  • Both sides of the logic board.
  • Hi-res pictures of the front and back.
  • Not for the faint of heart -- full-size images (5 MB a pop!): front and back.
Step 16  ¶
Image 1/1:
Step 16  ¶
  • And here's the whole enchilada for you to enjoy.
