Help
HTC EVO Design 4G Headphone Jack Replacement
Slice and Dice
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
This guide provides instructions on how to access the headphone jack of an HTC EVO Design 4G in order to replace the component.
  • Author: Lilian Nguyen
  • Time estimate: 45 minutes - 1 hour
  • Difficulty: Difficult
Replacing this component requires intricacy and caution with moving internal parts and circuitry inside the phone to avoid further damage to the other functionalities. Proceed with caution using a soldering iron used to detach the headphone jack.
Step 1 Headphone Jack  ¶
Use solder sucker to remove solder from the  front of head phone jack Use solder sucker to remove solder from the  back of head phone jack
  • Use solder sucker to remove solder from the front of head phone jack
  • Use solder sucker to remove solder from the back of head phone jack
  • There are 5 soldering locations from the top view and 5 locations from the bottom view
  • Remove the piece of tape covering the underside of the headphone jack. It will not have to be reattached
  • Refer to the How To Solder and Desolder Connections guie if needed
  • Solder sucker will be very hot
