Help
Sony DVP-FX730 Monitor Replacement
Grammar Police
Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Action Shots
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
This guide shows how to detach the screen from the main device.
  • Author: Andrew Ward
  • Time estimate: 10 minutes
  • Difficulty: Moderate
If the monitor or screen is broken, the monitor needs to be detached from the device.
Step 1 Monitor  ¶
Use your hand to remove the small back cover. Use your hand to remove the small back cover.
Step 1 Monitor  ¶
  • Use your hand to remove the small back cover.
Step 2  ¶
Remove the two 0.473" pan head screws.
Step 2  ¶
  • Remove the two 0.473" pan head screws.
Step 3  ¶
The screen should now detach from the main device.
Step 3  ¶
  • The screen should now detach from the main device.
  • The screen will still be connected by the wires.
Step 4  ¶
Remove the wires attached to the white base by using the tweezers. Remove the wires attached to the white base by using the tweezers.
Step 4  ¶
  • Remove the wires attached to the white base by using the tweezers.
Step 5  ¶
Do the same with the wires attached to the black base. Do the same with the wires attached to the black base.
Step 5  ¶
  • Do the same with the wires attached to the black base.
Step 6  ¶
The screen should now be completely separated from the main device.
Step 6  ¶
  • The screen should now be completely separated from the main device.
