Help
General Electric Create Jason Wu Battery Replacement
This is a solution for a faulty camera battery.
  • Author: Kailee Poe
  • Time estimate: 5 - 10 minutes
  • Difficulty: Moderate
This guide will exhibit the steps necessary to replace the battery on your General Electric Create Jason Wu.
Step 1 Battery  ¶
Using the Curved Precision Tweezers, detach battery plug from socket. Some may find the tweezers unnecessary for this step and instead may use their fingers to gently detach the plug.
Step 1 Battery  ¶
  • Using the Curved Precision Tweezers, detach battery plug from socket.
  • Some may find the tweezers unnecessary for this step and instead may use their fingers to gently detach the plug.
Step 2  ¶
Swap the 3.0 Flathead bit into the precision screw driver. On the front of the camera locate the small rectangular slot where the battery is exposed. Use the flathead bit to gently pry on the battery to start pushing it out of the camera, allowing it to become loose.
Step 2  ¶
  • Swap the 3.0 Flathead bit into the precision screw driver.
  • On the front of the camera locate the small rectangular slot where the battery is exposed.
  • Use the flathead bit to gently pry on the battery to start pushing it out of the camera, allowing it to become loose.
  • Do not pull the battery out too hard or the wires will break.
