Help
MacBook Unibody Model A1278 Lower Case Replacement
Replace the aluminum bottom case in a MacBook Unibody.
Step 1 Lower Case  ¶
Remove the following eight screws securing the lower case to the chassis:
Step 1 Lower Case  ¶
  • Remove the following eight screws securing the lower case to the chassis:
  • One 3 mm Phillips screw.
  • Four 3.5 mm Phillips screws.
Step 2  ¶
Using both hands, lift and remove the lower case off the upper case.
Step 2  ¶
  • Using both hands, lift and remove the lower case off the upper case.
