Help
HP Pavilion dv6500 Speaker Replacement
Better Introduction
Better Introduction
Improve this guide by completing or revising its introduction.
This guide will help users replace the speaker of their laptop
  • Author: Andrew
  • Difficulty: Moderate
Step 1 Speaker  ¶
Remove all 4 of the 7.0mm screws and the 3 silver, smaller  4.0mm screws inside the cavity of the battery
Step 1 Speaker  ¶
  • Remove all 4 of the 7.0mm screws and the 3 silver, smaller 4.0mm screws inside the cavity of the battery
Step 2  ¶
Gently lift the plastic panel on the top of the laptop at the divide until the two ribbon cables and cable leads are visible with their ports on left side on laptop. Gently lift the plastic panel on the top of the laptop at the divide until the two ribbon cables and cable leads are visible with their ports on left side on laptop.
Step 2  ¶
  • Gently lift the plastic panel on the top of the laptop at the divide until the two ribbon cables and cable leads are visible with their ports on left side on laptop.
Step 3  ¶
Gently pull on the 2 ribbon cables until they detach from the computer.
Step 3  ¶
  • Gently pull on the 2 ribbon cables until they detach from the computer.
  • Unplug cables connecting the top keyboard assembly and computer body.
  • Be careful not to rip the speaker cables.
