Help
HP G60T-600 CTO Keyboard Replacement
This guide will show you how to replace your broken or malfunctioning keyboard on this device.
If you have a broken or malfunctioning keyboard on the device, this is your guide.
Step 1 Keyboard  ¶
Unscrew the following 5mm screws with a #0 Phillips screwdriver. Unscrew the following 5mm screws with a #0 Phillips screwdriver.
Step 1 Keyboard  ¶
  • Unscrew the following 5mm screws with a #0 Phillips screwdriver.
Step 2  ¶
Turn your laptop over and open it up.
Step 2  ¶
  • Turn your laptop over and open it up.
  • Grip your laptop firmly from both sides and use your thumbs to slide the keyboard towards the screen.
Step 3  ¶
Pull up on the top of your keyboard with medium force. It should start to pop out.
Step 3  ¶
  • Pull up on the top of your keyboard with medium force. It should start to pop out.
  • A plastic opening tool may facilitate this task.
  • Run your hands underneath the edges of the keyboard until it is free from the device.
  • Do not pull hard to take the keyboard out. There is a small connection that needs to be undone.
Step 4  ¶
Place your thumbs on the two small, white tabs. Push these tabs forward to release the connection and free the keyboard from the device.
Step 4  ¶
  • Place your thumbs on the two small, white tabs.
  • Push these tabs forward to release the connection and free the keyboard from the device.
