Help
HP G60T-600 CTO RAM Replacement
This guide will show you how to replace/upgrade RAM for this device.
You will be removing a small plastic cover to get to your device's RAM, then with a couple short steps you will be able to remove it.
Sections
Tools
Step 1 RAM  ¶
Turn your device over and orient it so the battery is facing you.
Step 1 RAM  ¶
  • Turn your device over and orient it so the battery is facing you.
Step 2  ¶
Unscrew the following 5mm screws using a Phillips head #0 screwdriver. Remove the cover. Remove the cover.
Step 2  ¶
  • Unscrew the following 5mm screws using a Phillips head #0 screwdriver.
  • Remove the cover.
Step 3  ¶
Place your fingers on little metals tabs on both sides of the RAM casing. Push the tabs towards the sides. This should cause the RAM to pop up. Push the tabs towards the sides. This should cause the RAM to pop up.
Step 3  ¶
  • Place your fingers on little metals tabs on both sides of the RAM casing.
  • Push the tabs towards the sides. This should cause the RAM to pop up.
Step 4  ¶
Pull on it with medium force at the angle it is oriented.
Step 4  ¶
  • Pull on it with medium force at the angle it is oriented.
