Help
Motorola XOOM 2 Media Edition Speakers Replacement
This guide will explain how to replace the speakers on your device.
  • Author: Jillian Cain
  • Time estimate: 2 - 4 minutes
  • Difficulty: Easy
Are your speakers not working? Having trouble hearing your favorite music? Here is a guide to replace the speakers. You will need to purchase new speakers before beginning.
Step 1 Speakers  ¶
Using the tweezers, gently pull up the connector of each of the speakers. Using the tweezers, gently pull up the connector of each of the speakers. Using the tweezers, gently pull up the connector of each of the speakers.
Step 1 Speakers  ¶
  • Using the tweezers, gently pull up the connector of each of the speakers.
Step 2  ¶
Once the connector is removed, use the tweezers to pull up the speaker from its plastic socket on both of the speakers. Once the connector is removed, use the tweezers to pull up the speaker from its plastic socket on both of the speakers.
Step 2  ¶
  • Once the connector is removed, use the tweezers to pull up the speaker from its plastic socket on both of the speakers.
