Help
Olympus Camedia D560 LCD Screen Replacement
Needs More Images
Needs More Images
A few more images would make this guide's procedures crystal clear.
We will demonstrate removal of the LCD screen.
We will show how to tear down to and remove the LCD screen.
Step 1 LCD Screen  ¶
Unscrew all immediately visible screws on the body of the camera. Locations (# of screws): Bottom of camera (3), left side near video port (2), under cover of USB slot (3), memory card slot (1).
Step 1 LCD Screen  ¶
  • Unscrew all immediately visible screws on the body of the camera.
  • Locations (# of screws): Bottom of camera (3), left side near video port (2), under cover of USB slot (3), memory card slot (1).
Step 2  ¶
Use the plastic opening tool to separate the back cover from the camera. Use the plastic opening tool to separate the back cover from the camera. Use the plastic opening tool to separate the back cover from the camera.
Step 2  ¶
  • Use the plastic opening tool to separate the back cover from the camera.
Step 3  ¶
With the back plate off, locate two screws: one diagonal from the top left of the LCD screen and one diagonal from the top right of the LCD screen. Unscrew both of these screws. Unscrew both of these screws.
Step 3  ¶
  • With the back plate off, locate two screws: one diagonal from the top left of the LCD screen and one diagonal from the top right of the LCD screen.
  • Unscrew both of these screws.
Step 4  ¶
Flip the LCD screen over.
Step 4  ¶
  • Flip the LCD screen over.
Step 5  ¶
Undo the clip holding the ribbon cable that attaches the LCD screen to the motherboard.
Step 5  ¶
  • Undo the clip holding the ribbon cable that attaches the LCD screen to the motherboard.
Step 6  ¶
Unclip the plug attached to the red and white wires that connects the LCD screen to the motherboard. Unclip the plug attached to the red and white wires that connects the LCD screen to the motherboard.
Step 6  ¶
  • Unclip the plug attached to the red and white wires that connects the LCD screen to the motherboard.
Step 7  ¶
The LCD screen housing should now be free of the camera. The LCD screen housing should now be free of the camera. The LCD screen housing should now be free of the camera.
Step 7  ¶
  • The LCD screen housing should now be free of the camera.
