Help
Mad Catz Rock Band 4 Wireless Fender Strum Bar Replacement
This guide will show how to replace the strum bar from your Mad Catz Rock Band 4 Wireless Fender.
The strum bar is the approximately two inches long white bar on the Mad Catz Rock Band 4 Wireless Fender. Being one of the main components used to play Mad Catz Rock Band 4, it is prone to breakage after long hours of gaming. This guide is to help you figure out how to replace the strum bar in case of any causalities.
Be sure to remove the batteries before beginning.
Sections
Tools
Step 1 Strum Bar  ¶
Using a size J1 head screwdriver, remove the six black 5 mm screws (circled in red) from the back of the strum button component.
Step 1 Strum Bar  ¶
  • Using a size J1 head screwdriver, remove the six black 5 mm screws (circled in red) from the back of the strum button component.
Step 2  ¶
Lift out the circuit boards from above and below the strum component.
Step 2  ¶
  • Lift out the circuit boards from above and below the strum component.
  • Unplug the circuit boards connected to the strum component from the main circuit board.
  • You should now be able to pull out the strum bar.
