Help
Asus ROG G751JL-BB17T29 Hard Drive Replacement
Better Introduction
Better Introduction
Improve this guide by completing or revising its introduction.
This guide will show how to remove the Hard Drive housing Cover and allow fro the removal and replacement of the Hard Drive.
Step 1 Hard Drive  ¶
Lift the rubber cover on the back of the laptop. Remove screw with a Phillips screwdriver.
Step 1 Hard Drive  ¶
  • Lift the rubber cover on the back of the laptop.
  • Remove screw with a Phillips screwdriver.
Step 2  ¶
Using the nylon spudger, remove the back center panel. Using the nylon spudger, remove the back center panel. Using the nylon spudger, remove the back center panel.
Step 2  ¶
  • Using the nylon spudger, remove the back center panel.
Step 3  ¶
Remove the four 2.4 mm screws securing the left hard drive with a  Phillips screwdriver. Use the pull-tab to lift the hard drive housing and pull the hard drive away from the connector.
Step 3  ¶
  • Remove the four 2.4 mm screws securing the left hard drive with a Phillips screwdriver.
  • Use the pull-tab to lift the hard drive housing and pull the hard drive away from the connector.
Step 4  ¶
Remove the four 2.4 mm screws securing the right hard drive housing with a  Phillips screwdriver. Use the pull-tab to lift the hard drive housing and pull the hard drive away from the connector. Use the pull-tab to lift the hard drive housing and pull the hard drive away from the connector.
Step 4  ¶
  • Remove the four 2.4 mm screws securing the right hard drive housing with a Phillips screwdriver.
