Help
Toshiba Satellite R15-S829 Keyboard Replacement
This is a guide on how to replace your keyboard if your keyboard isn't functioning properly.
  • Author: Mike Strother
  • Time estimate: 5 minutes
  • Difficulty: Moderate
If you need to replace your keyboard on your own, here is an easy process on how to complete this task. All you need is a a new keyboard and a Phillips screwdriver. Be careful while replacing so you don't break anything internally. Now you are ready to get started.
Step 1 Keyboard Replacement  ¶
First, begin  by removing the plastic cover that is located at the top of the keyboard.  This can be pried off or just removed by hand by grabbing the  plastic piece by the indent on either side and lifting up. Be careful to avoid breaking the plastic.
  • First, begin by removing the plastic cover that is located at the top of the keyboard. This can be pried off or just removed by hand by grabbing the plastic piece by the indent on either side and lifting up.
  • Be careful to avoid breaking the plastic.
Step 2  ¶
Locate the two screws on each side.
Step 2  ¶
  • Locate the two screws on each side.
Step 3  ¶
Remove the two screws with a phillips head screwdriver. Be careful not to lose the screws. Remove the two screws with a phillips head screwdriver. Be careful not to lose the screws.
Step 3  ¶
  • Remove the two screws with a phillips head screwdriver. Be careful not to lose the screws.
Step 4  ¶
Lift the keyboard up to reveal the power plug. Lift the keyboard up to reveal the power plug.
Step 4  ¶
  • Lift the keyboard up to reveal the power plug.
Step 5  ¶
Disconnect the keyboard from the laptop by unplugging the power ribbon. Disconnect the keyboard from the laptop by unplugging the power ribbon.
Step 5  ¶
  • Disconnect the keyboard from the laptop by unplugging the power ribbon.
