Help
iPod Touch 6th Generation Battery Replacement (UNCOMPLETED)
In Progress
In Progress
This guide is a work in progress. Reload periodically to see the latest changes!
Member-Contributed Guide
Missing Details
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
In this guide I will show you How to replace the iPod touch 6th generation's Battery
  • Author: Aiden
  • Difficulty: Difficult
( UNCOMPLETED )
Step 1 Power Down Device  ¶
Press and hold the Sleep/Wake Button (Power Button) for about 4 or 5 Seconds. The Slide to Power off
  • Press and hold the Sleep/Wake Button (Power Button) for about 4 or 5 Seconds.
  • The Slide to Power off
Step 2 Display Assembly  ¶
If you have not removed the display assembly view my first 12 steps in my screen replacement guide (iPod touch 6) for steps to remove the display assembly (Click here to go)
Step 3 Battery  ¶
Remove the covering over the battery by applying heat
Step 3 Battery  ¶
  • Remove the covering over the battery by applying heat
Step 4 Removing Battery  ¶
There is a piece of tape over the battery connectors Remove tape over battery connectors using a pair of tweezers.
  • There is a piece of tape over the battery connectors
  • Remove tape over battery connectors using a pair of tweezers.
Step 5  ¶
In this step we will desolderer the battery from the logic broad.
Step 5  ¶
  • In this step we will desolderer the battery from the logic broad.
  • I recommend using a desolder tool, you can buy one here Desoldering Braid (iFixit.com)
  • Apply Desolder paste or Braid to the 3 strips of solder
