Help
Braven BRV-HD Motherboard Replacement
Using this guide you will be able to identify and replace the motherboard for the Braven BRV-HD Bluetooth Speaker.
Following this guide will show you how to access and replace the motherboard. The Braven BRV-HD Battery Replacement is a prerequisite for this guide.
Sections
Tools
Step 1 Motherboard  ¶
Locating the two screws on either side of the motherboard, unscrew the two 8 mm Phillips head screws using a J1 Phillips head screw driver. Locating the two screws on either side of the motherboard, unscrew the two 8 mm Phillips head screws using a J1 Phillips head screw driver. Locating the two screws on either side of the motherboard, unscrew the two 8 mm Phillips head screws using a J1 Phillips head screw driver.
  • Locating the two screws on either side of the motherboard, unscrew the two 8 mm Phillips head screws using a J1 Phillips head screw driver.
Step 2  ¶
Slide out the motherboard using your hands. Unplug all the wires attaching the motherboard to the device. Remove and replace motherboard.
Step 2  ¶
  • Slide out the motherboard using your hands.
  • Unplug all the wires attaching the motherboard to the device.
  • Remove and replace motherboard.
  • Some wires are glued to the motherboard with a green glue. Remove the glue before removing the wires.
