Help
Nabi Big Tab HD24 Nabi Port Replacement
Replacing the nonfunctional Nabi port so that when you connect devices the ports will function.
  • Author: Kelvin Cao
  • Time estimate: 30 minutes
  • Difficulty: Moderate
There are four Nabi ports that are available to use. The Nabi ports are specific ports from Nabi that requires a USB adapter in order to connect a USB device to the tablet. Before replacing the Nabi port, determine which port is faulty, as there are four ports to choose from.
Step 1 Nabi Port  ¶
Locate the nonfunctional Nabi port; there should be one on each side of the tablet.
Step 1 Nabi Port  ¶
  • Locate the nonfunctional Nabi port; there should be one on each side of the tablet.
  • The circuit board of the Nabi Port has a ribbon connector attached to it and there should be a blue strip of tape at the end of the ribbon connecting to the board.
Step 2  ¶
Locate the black tab which secures the blue end of the ribbon cable to the Nabi port. Lift up the black tab to release the ribbon cable.
Step 2  ¶
  • Locate the black tab which secures the blue end of the ribbon cable to the Nabi port.
  • Lift up the black tab to release the ribbon cable.
Step 3  ¶
Pull the ribbon connector away from the circuit board to disconnect it. Pull the ribbon connector away from the circuit board to disconnect it.
Step 3  ¶
  • Pull the ribbon connector away from the circuit board to disconnect it.
Step 4  ¶
Unscrew the 4.5 mm silver screw holding the Nabi Port in place.
Step 4  ¶
  • Unscrew the 4.5 mm silver screw holding the Nabi Port in place.
  • Lift out the Nabi Port and replace it with your new one.
