Help
Sony Ericsson s710a SIM Card Replacement
Mismatched Prerequisites
This guide does not have a proper prerequisite guide. Help match it to its ideal partner by finding it or writing one!
This guide will walk you through how to install/replace the SIM card in the Sony Ericsson s710a cellular phone.
  • Author: Alexander
  • Time estimate: 5 minutes
  • Difficulty: Moderate
This is a GSM phone originally introduced by AT&T. The SIM card will likely be an AT&T card; however, when in foreign countries, other SIM cards can be inserted into the phone for compatibility with foreign carriers.
Step 1 SIM Card  ¶
Slide the battery cover off by pushing it away from the camera side of the device.
Step 1 SIM Card  ¶
  • Slide the battery cover off by pushing it away from the camera side of the device.
  • This may require a good amount of force.
Step 2  ¶
Next remove the battery
Step 2  ¶
  • Next remove the battery
  • Lift it out of the phone using the tab on the battery (marked in the image)
Step 3  ¶
The SIM card holder is now exposed (marked in image).
Step 3  ¶
  • The SIM card holder is now exposed (marked in image).
  • This will likely already have an existing SIM card in it if the phone has been previously used.
  • To open this, slide the holder upward (assuming the same orientation as in the image)
Step 4  ¶
The holder will then hinge open.
Step 4  ¶
  • The holder will then hinge open.
  • You are now able to insert a new SIM card.
Step 5  ¶
Insert the new SIM card in the orientation shown.
Step 5  ¶
  • Insert the new SIM card in the orientation shown.
  • This is important, as the phone will not work if the metal contacts on the card are not properly aligned with the contacts on the phone.
Step 6  ¶
Now hinge the SIM card holder down so that it lays flat in the phone.
Step 6  ¶
  • Now hinge the SIM card holder down so that it lays flat in the phone.
  • Slide the plastic holder downwards to lock it in place.
  • Now the battery and cover can be put back in place.
